Link USB6009 with Sat Finder + Dish and acquire
Hi, I'd like to build a radiotelescope and acquire signal in Volts from the sun.
I have a Ni-daq USB 6009 with a Sat Finder. I've linked the 2 clamps of the sat finder to the pin 2,3 of the DAQ (channels AI0 and AI4,right?Same AI0+ and AI0-).
Now what should i do to acquire the signal?Use a differential or RSE mode?
I've also created a little software in Labview to acquire but i have doubts about channels for the DAQ assistant and mode to acquire.
Can someone help me please?
Thanks and sorry for my not perfect English.
(2,908 Views)
Connection seems to be correct; about the different type of acquisition I suggest you to read the following document:
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
Hope this helps.
(2,805 Views)
