Linking problem with nidaq32.lib
I followed all the steps in the User Manual for User PC Compatibles to create a windows application using Borland c++. When I run the project for the first time I have a linking erro related with this import library. How to solve this problem?
(2,900 Views)
In Borland you will want to link to nidaq32b.lib and niex32b.lib. These will be installed when you install support for Borland from our NI-DAQ diver.
You can find information about running NI-DAQ in Borland at this KB:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/d59e4d28ca9e1df6862565680080f22a?OpenDocument
Kevin R
(2,900 Views)
