Linux Drivers for USB-6229 DAQ
I'd like to use a USB 6229 with Linux and the driver support selection guide says this model is unsupported.  However, the 6218 and others are supported.  Is it possible to use the 3.5B driver set for a USB 6229 with reduced functionality?  Is it possible, with some basic Linux driver coding knowledge, to modify the 3.5B drivers to work with a USB 6229?
Craig
Message 1 of 8
(5,258 Views)
Hi Craig,
Unfortunately there isn't really a way to do this. The 6229 and 6218 are from the same M series DAQ family. However, their different functionality means they have different hardware architectures. Furthermore there isn't a simple way to modify the driver specifically for the USB 6229. To develop a custom driver for the device you would have to know the low-level driver commands and the hardware architecture of the device itself.
Sorry. Hopefully this helps clarify though.
Chris G
Message 2 of 8
(5,243 Views)
Hi Chris,
Thank you for your reply.
I have downloaded the B3.5 driver package, and in the readme there is a section that suggests the PCI version of the 6229 has driver support in Linux.  Is this correct?
Craig
Message 3 of 8
(5,241 Views)
Accepted by topic author OptEng
Hi Craig,
That is correct.
Best,
Jeff S.
Message 4 of 8
(5,215 Views)
Hello Craig,
I'm also interested in using USB-6229 DAQ under linux and I have no idea what B3.5 driver package is
I wonder if you can proivide a link for that package
Thanks in advance
Hosam
Message 5 of 8
(4,961 Views)
The 8.0.2 driver set is better for Linux, it contains an extended library of function calls.
http://www.ni.com/download/ni-daqmx-8.0.2/2322/en/
It works well on Scientific Linux 5.  SL 6 wasn't as easy.  The Red Hat and SUSE installations weren't tried here.
The B3.5 driver set is limited in functionality.  Good luck.
Message 6 of 8
(4,948 Views)
Thanks for the reply Smiley Happy
I'm actually using Ubuntu, is there a version for Ubuntu?
Message 7 of 8
(4,935 Views)
I'm not in any way associated with NI (obligatory disclaimer :^) )...
I would recommend abandoning Ubuntu in favor of a supported Linux variant unless you really like recompiling kernels.  If you choose the Ubuntu route, there are other people on this forum who have recompiled unsupported Linux variants with varying degrees of success.
Good luck.
Message 8 of 8
(4,927 Views)
