Linux and PCI, serial, RS232 4 port
Dear All,
Please, how can I install this board (PCI, serial, RS232/485, isolated, 4 port) (185729D-01) in Linux (Debian 5.0)
I found this board in our lab and would like to use it in Linux.
Thanks for any suggetion,
Jose
(3,574 Views)
Debian is not supported by NI products. If you would like to use linux with NI products visit the following website to view what products works with linux and what linux distribution are supported by NI products.
Abel
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,562 Views)
The RS232 version of this board will work with kernel 2.6.30 and newer.  All you need to do is plug the board in and you should have 4 new serial ports.  Of course 2.6.30 is still in development so you would need to build a custom kernel yourself or try to find a deb package of one of the development kernels.
If you don't want to mess around with development kernels you can try taking a look at this guide:
 Using PCI Serial with Linux
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
(3,549 Views)
Thanks for your help.
I will use your suggestion and report the results.
Jose
(3,536 Views)
