Linux driver for usb-6341
I noticed from the ni driver support page that there is no linux driver for daqmx usb-6341 or usb-6343. Is a driver possible comming in the near future?
niiraka
(5,751 Views)
Unless NI is willing to disclose their ultra-military-secret specs, it's quite unlikely.
The USB subsystem enforces all consuming drivers to be GPL. (iow: fully disclosed),
which they just refuse.
http://forums.ni.com/t5/Multifunction-DAQ/Linux-NIDAQmx-install-problem/m-p/3225670/highlight/false#...
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(4,653 Views)
This was a while ago, today is 9 years later.
Has Linux support for these cards "magically" appeared now?
(2,921 Views)
This is the current status - https://www.ni.com/en-us/support/documentation/supplemental/18/daqmx-for-desktop-linux-tools.html
Santhosh
Soliton Technologies
(2,902 Views)
Thank you for the pointer!
Oddly enough, following the installation instructions to the letter still results in a non-functional system.
I am on Ubuntu 22.04.1, kernel 5.15.0-56.  The install completes, but then any data transfer fails with error -50152, which I think is the code for DMA not working!  The easiest way to see this is to run self-calibration via ni-hwcfg-utility.
(2,809 Views)
