Load cell connection and calibration using HX711 and USB-6009 in LabView
I have the following instruments:
  • DAQ USB-6009
  • Arduino UNO
  • HX711
  • UDA Load cell (500kg)
Mi problema es el siguiente:
I need to measure the data from the load cell to my DAQ, since it has a higher resolution than the Arduino.
The problem is that, to amplify the cell signal, I don't know how to program the HX711 from LabView. Should I use Arduino, or what would be the steps to follow for the connections and programming?
Message 1 of 1
(820 Views)
