Long delay occures while running a VI involving usb data acquisition
I am acquiring 15 analog signals throu NI DAQPad-6015. There are also 2 counter outputs and one analog output as well. The problem is when I Run my VI, it takes a long time to start acquiring data. During this delay at the start it doesnt do any thing and just halts. After this delay it some times throws the data on the chart and then stabilizez or it hangs completely in which case I have to stop the VI. My sampling rate is 400Hz at 200 samples and using the traditional VIs for configuring and setting up the channels.
How can I rectify this intial long delay?
(3,437 Views)
Hello shafiq,
This is an extremely application-specific question. Without more information on your application (preferably the code to reference) it would be very difficult to narrow down where the slow down is occurring and where it would be possible to improve performance.
Dan King
(3,425 Views)
Well, I am trying to fix it and I assume it is some thing to do with optimizing the sampling rate and samples  per scan. The delay changes when I change the sampling rate or the samples per scan. I would let you guys know if I can find the most appropriate solution. Until then I would appreciate if any body could give suggestion/comments.
Shafique
(3,403 Views)
And why can't you attach your program like it was suggested?
(3,401 Views)
The image of the block diagram is now attached. The rest of the program, which is not shown in the image is some calculation.
Shafique
(3,390 Views)
