Low cost control for solenoid valves
I need to switch 7-9 24V solenoid valves (between 0.2A and 0.8A draw each) at a short distance from the main PC, so I want to run just USB or just ethernet.
I am already going to use a USB Multifunction DAQ (USB-6008) for analog input to take sensor readings. It would be nice to use the TTL-signals from DIO of that card to switch industrial relays (DIN mountable), but the only products I could find were non-industrial relay boards with built in transistors, intended for Arduino/Raspberry Pi. So the solution I have is adding another USB DAQ with SSR outputs (USB-6525) and using that to drive the coils of industrial relays.
Is there a better way to do this? Are their industrial relays that take TTL-level input? Is there an NI card to handle all of this?
(2,840 Views)
There are industrial SSR (solid state relays)with DIN rail mounting that can directly be controled by the 600x (5V 8mA)
EMG 17-OV-TTL/ 24DC/2
is one search result.
But using 8 of them might cost you more than going the NI 9472 plus chassis way and if you look for industrial solutions I would question a 600x 😉
Greetings from Germany
Henrik
LV since v3.1
(2,814 Views)
here is anotherone
and here the DRA1-MPDCD3 seems to fit
Henrik
LV since v3.1
(2,812 Views)
I have used these before.
https://www.mcmaster.com/#8299K12
(2,804 Views)
