Low frequency FSK demodulation, less than 100kHz
I am trying to demodulate an ultrasonic FSK signal, which will be less than 100kHz, most likely 20-45kHz.  I am looking for a simple way to decode this, I have tried the Delay & Multiply method, but I have not had much sucess with it.
Are there any example VI's showing this?
(4,663 Views)
Hi ademedeiros,
I was able to find this example in our website (ni.com/code) and it is a modulation/demodulation VI for FSK.
I hope this helps!
steve.bm
AE | NI
(4,653 Views)
Hi Steve,
Thankyou for your help. That example uses the Modulation toolkit as well as RF hardware. I am looking for an example, or guidance in demodulating FSK acquired by an M-Series Daq.
(4,649 Views)
Hi ademedeiros,
Sorry for that, I found these two other examples:
Implement FSK with X-Series and DAQmx
Modulation Toolkit 2-FSK to Baseband Example Using DAQmx
I hope this helps!
steve.bm
AE | NI
(4,637 Views)
Hi Steve,
Thanks again for your help. These examples are extremly helpful, but they are for modulation, not demodulation. Is there anyway to use DaqMX and the toolkit for demodulating FSK?
(4,633 Views)
Hi ademedeiros,
The Modulation Toolkit has a FSK demodulate function, you can use this for the demodulation phase. What you can try to do is to set up a analog acquisition task and send the data that you get to the demodulate VI. That should work for your need.
steve.bm
AE | NI
(4,625 Views)
Seems that one of the links is broken, this is the correct one:
steve.bm
AE | NI
(4,623 Views)
