M Series NI6221 counters - input levels
I' ve to measure the frequency of a signal with null mean value and 5Vpp amplitude, through the counter input.
Is it possible to make that without damage?
I think the digital inputs and the counters are protected by negative input levels.
Thank you
N.Roberto
(2,887 Views)
the dinamic range of counter input of NI 6221 is 0-5 V. Refer to specification page at https://www.ni.com/en-us/support/model.pci-6221.html.
At the same link under resources you can also find Mseries manual. Chapter 7 is about Counter application ( take a look to Frequency Measurement )
Clara
(2,863 Views)
