MATLAB cannot see my USB-9472 DAQ card
Hello. I am trying to connect matlab to a National Instruments "Ni USB-9472" DAQ cards. I have installed all the software and drivers, and my computer sees them fine; I can see them in "Measurement & Automation Explorer". The problem though is that MATLAB can't. When I try to access them, it says:"Failure to find requested data acquisition device: nidaqmx"I used the command "daqhwinfo.InstalledAdaptors" to see if it could see it, but all that was returned was " parallel" and "winsound", which I believe means it does not even recognize the driver. The cards work fine, my other older computer that has been doing this for a while can see it fine. I am running windows Vista, and matlab 7.8.0 (R2009a). Any ideas? Thanks
(3,666 Views)
It sounds like a MATLAB issue that was resolved on this forum:
http://www.mathworks.com/matlabcentral/newsreader/view_thread/253373
h_baker
(3,646 Views)
Yep, thats it. That actually was my post on the MATLAB forum. When I got the solution there, I tried to come back here to post that it was solved, but couldn't figure out how to navigate NI's forums to look at my posts, so I gave up. Thanks though
(3,643 Views)
