hi george,
first, thank you for helping me!
When i apply a voltage on a channel, calling the task with CVI, i can read the good value on the channel, but as itell you before, i can read it only one time.
i check the channel with an oscilloscope, and i only write the voltage value only one time althought i defined it in continuous mode in MAX, and i don't know how use the task in CVI to apply the voltage in continuous on the channel.
i can't use a loop because i don't want interruption in the voltage apply.
how can i do?
i join you the MAX config an d my .cif you want look at them.
thanks.
Nico.
