MAX3.0 hangs during test panels of virtual channels
While calibrating channels, we are running MAX3.0. I right clicked on a virtual channel (analog input through SCXI-1100 and PC-MIO-16E-4). It opened the properties panel, but the program hung. THis has happened on at least 3 different virtual channels. Other programs (including Labview 6.0) ran, but MAX locked up. I could not get MAX to do anything, or even close it. Using CTRL-ALT-DEL and asking Task Manager to close it gives a message that the program is not responding; clicking End Now gives a message that the program cannot be closed, and check if it is being debugged (it isn't, that I know of). I had to turn off power to the computer to reboot.
This has happened several times, although at other times the prog
ram runs fine.
(2,382 Views)
Hey John,
I'm not sure of an exact fix for this problem. It's possible that the installation of MAX 3.0/NI-DAQ 7.0 was bad. I would suggest to uninstall NI-DAQ 7.0/MAX 3.0 and see if reinstalling helps fix the issue.
Todd D.
NI Applications Engineer
(2,382 Views)
