Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Magma expansion performance with NI PCI 6534
Bobby_K
Member
12-06-2004
02:46 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to use the Magma PCI expansion with a NI-6534 DIO card. I need 16 bits transfer from 2 MBytes/s up to 20 MBytes/s (1Mhz to 10Mhz).
Will the PCMCIA card between Magma card and the laptop slow down the transmission?
0
Kudos
Message
1
of 2
(2,740 Views)
Reply
Re: Magma expansion performance with NI PCI 6534
Marc L.
NI Employee (retired)
12-29-2004
11:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
To give a correct answer I would need to know your exact configuration :
Which Magma PCI expansion do you want to use ?
Could you explain with more details the different connexions?
regards
Marc Larue
NIF
0
Kudos
Message
2
of 2
(2,701 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
