Manipulating Arrays for Galvo Control in B-Scan
Hello everyone,
I’m working on a project that involves controlling galvo mirrors for horizontal and vertical scanning, similar to a B-scan. I need assistance with manipulating arrays for this purpose. Specifically, I am looking to achieve the following:
  1. Ascending and descending order of array values.
  2. Interchanging the X and Y values for horizontal and vertical scanning.
Could anyone provide guidance or examples on how to implement these manipulations? Any help would be greatly appreciated!
Thank you!
(257 Views)
I recommend to do a "save fore previous" ((e.g. 2019) and attach again so more can see your program. Many don't have LabVIEW 2024.
(233 Views)
OK, I had a chance for a quick look.
  • Please clan up your file names. Don't attach a VI named "wavePosSub (1).vi" it the caller wants "wavePosSub.vi"
  • Please don't maximize the front panel and diagram to the screen.
  • If you attach a fine ending in "working", can we assume that the result is correct and you are just asking to simplify the code?
  • There are more efficient way to tell if a number is even or odd.
  • I doubt there is any need for temporary 3D arrays.
We don't have your hardware, so please reduce the code to the array generation so we can run it.
(212 Views)
Things get significantly easier if you would clean up and simplify your code. You don't evenneed any subVIs.
Here's a literal translation of your code. Use it as a start to implement your new requirements.
(202 Views)
