Manual trigger using external button
Probably a real newbie question:
I am trying to use an external momentary button to record pulses. The button is connected to the 5v+ output and aio of the bnc 2110. When I connect the button to the oscilloscope I see clear 5V step each time I press the button however when I connect the button to the ai0 and record in matlab using the analogInputRecorder the signal doesn´t make sense. What am I doing wrong?09230803_p.png
(2,562 Views)
I would say it is time to go back to the basics to see where the problem is.  I would start by going into MAX and see if you get the signal using the test panel for the device.  If it does not work correctly in MAX I doubt you will get it to work in matlab.
(2,501 Views)
