Max number of samples per channel
How can I calculate the max number of samples per channel I can adquire? I'm working with analogic signals and with a multiplexor.
(2,551 Views)
What National Instruments hardware are you using? Each National Instruments data acquisition device has a unique sampling rate. You can find the maximum sampling rate of the device within the specifications section of the user manual. You can search for the user manual of your device from the link below.
Search Manuals
http://search.ni.com/?layout=ProductManual
Todd D.
(2,551 Views)
