Max sampling rate in ConfigureSampleClock on a PICe-6323
I am using C# in Visual Studio to program a PCIe-6323. I wondered what's the maximum sampling rate, which is the 2nd paramter in ConfigureSampleClock(), that the card can handel?
(4,353 Views)
I mannually tried the maximum value that the function allows is 5000. Now there are mulitiple sample rates listed in the mannual. Which one tells me the 5000? I am trying to learn the language.
Thanks!
(4,340 Views)
Accepted by topic author joehsiao
The maximum sample rate for an analog input is 250000 samples per second. I have no idea where you see 5000 is the maximum.
(4,338 Views)
You are right. My mistake. I forgot I was testing with a USB-6002 instead.
(4,319 Views)
