Maximum cDAQ trouhgput
Hi there,
If I have cDAQ 9179, full with 14 NI 9220 C Series Analog Input Module, would it be possible to acquire continuously the full 448 channels (32*14) at a sample rate of 100kS/s ?
If no, what are the limitations ?
Thx,
(3,400 Views)
Any answer ?
Thx
(3,367 Views)
Accepted by topic author PragmaTest
     Hello Sébastien,
Have you seen that document?
What Is the Maximum Throughput On My cDAQ Device?
Does it answer your question?
Junior
(3,360 Views)
I think the last sentence in that linked pages is in error:
Because the total rate of data transfer during this application (8.6 MB/s) does not exceed the maximum throughput of the 9179's USB 3.0 bus (250 MB/s), there should be bandwidth issues acquiring data at these rates on this device.
It is missing 'not':
Because the total rate of data transfer during this application (8.6 MB/s) does not exceed the maximum throughput of the 9179's USB 3.0 bus (250 MB/s), there should NOT be bandwidth issues acquiring data at these rates on this device.
-AK2DM
(3,356 Views)
You are completely right!
(3,353 Views)
Yes, thank you very much.
(3,348 Views)
