May labview 7.0 be used with usb-6009 or 08 ? if not, what is the oldest usable version with usb-6008 / 09 ? Is a link product/compatibility available ?
Yes you can use your usb-6008/9 with LabVIEW 7.0 if you have the DAQmx driver installed.  The latest driver that works with this device is NI-DAQmx 8.1.  If you check out the readme on this driver you will find that it supports the USB-6008/9 and LabVIEW 7.0.  The links below show the DAQ version compatibility with LabVIEW and device driver compatibility.
NI-DAQ & LabVIEW Version Compatibility (for Windows)
NI-DAQ Driver Support: Portable Devices
Jordan F
(2,964 Views)
