May the file in /tmp/natinst be deleted?
Hello
My program that used DAQmx8.0 on Linux wants to record data without stopping more than a half year.
The cron.daily on linux deletes a file in /tmp/ in a constant condition.  Will not there be the problem?
Best regards.
(3,285 Views)
There could be problems caused by removing /tmp/natinst/ so I would recommend that you add an exception to your cron.daily script to not remove /tmp/natinst/
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
(3,241 Views)
Thank you for the answer.
My best regards thank you very much.
S.imazu
(3,221 Views)
