Measure 60mVpp with +/- 0.1mVpp
I have a signal that is  60mVpp AC. I want to measure the Vrms in LabView. What hardware could I use for this if I am  trying to detect a change as small as 0.1mVpp.
(4,990 Views)
There are more signal properties that need to be provided as well as form factor. You can browse the products (link at the top of the page ) or contact your local Sales Engineer.
(4,975 Views)
Dennis is right, but take a look at the NI PCIe-6320.  It should fit your application.
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(4,946 Views)
This additional information will help us narrow down the options:
-sample rate
-do you need accuracy or precision?  Sounds like precision ('detect a change'), but just making sure
NI's standard E/M/X series 'DAQ' cards likely won't get you 100uV accuracy (not to be confused with resolution).
My first recommendation is a DSA card, such as the PXI-4461, or the NI-4071 DMM.  I can make a much more informed decision with more information.
-John Sullivan
Problem Solver
(4,878 Views)
-sample rate
Sorry,
here is the spec of the 6251 (M?) DAQ
I would expect that you can measure a 60mVrms AC signal in the +-100mV range  and do better than 1100ppm absolute accuracy 🙂
But if the poster can give more information on frequency range , surrounding conditions (Lab, industrial , outdoor,..) , traceability, number of channels etc. there would make a difference in spending 600 or 10k $Unit 😉
BTW: 60mV AC in audio range with 0.1% relative change can be done with the line audio input of the soundcard 😄
Greetings from Germany
Henrik
LV since v3.1
(4,873 Views)
Hey Henrik, yes, the 6251 is an M series DAQ device.
Let's talk specs ;)...
If you read all the fine print, you'll need to average 100 samples to achieve the specified uncertainty.  You'll also need to stay very close to the external and internal self-cal temperatures, as those add uncertainty very quickly as temperature changes.  Assuming you stay within ±5°C of external and internal self cal, AND you average 100 samples, then yes, you can achieve 83.7uV* uncertainty in the 100mV range with a 60mV reading.
However, if our mutual comrade is looking for 100uV uncertainty, then I propose that 83.7uV uncertainty is not enough; typically, we want 4x less uncertainty on the measuring equipment.
If our mutual comrade is most interested in precision, then I propose looking at any of the various DSA cards (4431, 498x, 446x, etc).  If we look at the 4461, we can see that our gain error is much smaller.
Overall, I agree we need more information from our customer.
Have a great day
*Using equation in spec sheet:
60E-3*(150E.6+13E-6*5+1E-6*5)+100E-3*(150E-6+90E-6)+15E-6*3/sqrt(100)=83.7uV
-John Sullivan
Problem Solver
(4,860 Views)
