I am setting up a data acquisition system in which the user has the ability to select between multiple sources for the scan frequency. The user can choose either hardware based and select the scan frequency or an external source, in this case, an encoder. When the user selects the external case, I would like to measure the scan frequency. I have a PXI chassis with 3 6071E DAQ boards. I have the encoder pulse train wired into the master board and would like to use one of the slave boards to count the pulses and measure the frequency. I based the code I developed on example code that shipped with LabView. However, when I drive the master board with a known frequency using its internal clock,
I measure 0 frequency on using the slave boards counter.
