Measurement & Automation Explorer or the Instrument IO Assistant is not installed correctly
When I try to use the DAQ assistant, I receive the error message mentionned above. I am pretty sure that the problem does not come from MAX because it runs well, but I cannot find the instrument IO assistant. The error message says to reinstall this IO assistant but I do not find it in the window of the installation CD.
Clueless I am
(3,558 Views)
The Instrument IO Assistant is installed with NI-VISA. We have this knowledgebase article that outlines what you need to reinstall and the steps necessary to get there.
If you have any troubles, please let us know!
Peter E
(3,547 Views)
