Measurement and Automation
Hello all
                 I am facing a problem while synchronizing four PCI-6123 devices using RTSI cable.I am using "Measurement and Automation Software MAX"
I created RTSI in MAX and added four PCI-6123 devices to it. I created a task to acquire 32 AI channels simultaneously.However when i wanted to see connection diagram on MAX, an error occurs. Do i need to set some triggering type or MAX will automatically set it?
Note: I want to use internal clock for synchronization
(3,013 Views)
Hi ASIM_BHATTI,
What error are you receiving?
Luckily with DAQmx drivers 8.0 and later enables channel expansion making synchronization of multiple S-Series or DSA devices easier. Please referecence the following KnowledgeBase article that details how to program such an application.
Synchronizing DSA or S Series Devices With a Single NI-DAQmx Task
Glenn
Glenn
(2,987 Views)
