Measurement of resistance by USB 6009
I want to measure the resistance of 4 varying resistance by USB6009. When I choose "Resistance" in DAQ assistance it shows a unrelated values for the resistances. Is there any method to connect resistances and measure them?
(3,760 Views)
The 6009 (and all DAQ module/boards as far as I know) only measure voltage.  You can measure resistance by applying a know current through the resistor and measure the voltage drop and calculate the resistance.  You can also do a voltage divider with a know resistor in series and measure the voltage drops to calculate the unknown resistance.
(3,743 Views)
You may also want to look into the USB-4065, which is capable of taking resistance measurements.
(3,730 Views)
Thanks for the suggestions.
It seems that USB6009 can only apply and measure Voltage. Therefore, I am trying to use voltage divider to measure resistance. Is there any other method to measure resistance with USB6009?
Unfortunately, at this point I cannot buy another device.
Meysam
(3,725 Views)
As already written, you can use
a voltage divider
a bridge
a current source ( 1k and a BF245 makes about 1mA )
use the R in RC timer and measure the frequency
... the more important questions are :
application?
range?
uncertaincy?
Greetings from Germany
Henrik
LV since v3.1
(3,689 Views)
Depending on the values of resistance you need to measure, you may need to take into account that the analog input resistance is about 144Kohms. This may affect your results.
-AK2DM
(3,662 Views)
