Measurements and Automation 4.4.1 is not supporting VI logger lite
I have recently purchased USB 6221. I installed Measurements and Automation  4.4.1 software. It did not contain VI logger lite. So I downloaded it from net and installed it. Now I am facing following problems
1) The measurements and automation software is showing VI looger under configuration >> softwares >> VI logger. But I am not able to log data. It does not separatetly show VI logger under configuration tree i.e configuration >> VI logger.
2) When I seperately try to start VI logger Lite, measurements and automation software is launched instead with the above mentioned problem.
So how do I log my data using USB 6221. What are the possible solutions?
Trupti
(3,013 Views)
Also the driver I have installed is NIDaqmx 8.7.1
(3,000 Views)
You should be using Signal Express LE.
(2,992 Views)
