Measurements and Automation Software Restore
When I tried to take temperature data using my PCMIA NI 4350 card, the Measurements & Automation software was not seeing the drivers. This has happened before, so I removed and the card and restarted the computer shut it off, reinstalled the card and restarted it. Still didn't find the card. So, I decided to uninstall the software. It was running version 2.2. Reinstalled the software using version 2.1 disk. Now, can't find M&S icon on desktop. Cannot find upgrade. So, I am stuck with nothing running.
This system has worked well before. It has been several months since I have used it, but I am not aware of any system changes. But, something happened.
Don Bray
(2,452 Views)
Have you attempted to reinstall the NI-DAQ driver as well? In order to use this device you will need some version of NI-DAQ. I would recommend either version 7.3.1. If you are using Windows 98, you will need version 6.9.3 instead. You can get version 7.3 using this link:
http://digital.ni.com/softlib.nsf/websearch/2473339B54F5B34286256F380059D35B?opendocument&node=132060_US
or version 6.9.3 using this link:
http://digital.ni.com/softlib.nsf/websearch/50F49E43A22C0D2186256BF3006B9A96?opendocument&node=132070_US
(2,408 Views)
