Measuring pressure using NI cDaq 9174 and NI 9223 module
1. I am using a Kistler make piezoelectric pressure sensor with charged amplifier, using NI module 9223 as the sensor output is in volts. Sensor has three wires  - Output (1 wire) and power (2 wires); and requires 12 volt supply. I do not know how to obtain pressure data from this arrangement.
LD Kala
(3,831 Views)
Have you read the Kistler manual? If anything is unclear, I suggest you contact Kistler support first.
(3,807 Views)
Please provide some more information on your sensor and signal conditioner (charge-amplifier) Model name and/or link to datasheet would be helpful.
Greetings from Germany
Henrik
LV since v3.1
(3,794 Views)
Thanks Henrik.
The pressure sensor is Kistler 6613CQ09. The charged amplifier provides three wires - 1 signal, 1 power and 1 ground. The signal is voltage type.
I will connect signal to NI 9223 and power and ground to 12 V supply. Sensitivity of sensor is 25 mV/bar.
I understand the cDAQ will give output in mV and requires to converted into pressure. This conversion I am not clear about.
LD Kala
(3,786 Views)
Thanks. I have attached the sensor's data sheet for your reference.
L D Kala
(3,785 Views)
