Mechanical dimensions of DAQ OEM board
Looking for the mechanical dimensions of the USB-6003-OEM board so that I can design a PCB for this board to mount onto it. I have designed a calibration system using the 6003 board and now I'm am in the planning stages for the next board revision in which I want to "cut the cord" to that expensive USB-6003 enclosed module with the screw terminals and just mount the OEM board onto my board. I looked at the USB-6003 manual and all it showed was the pin-out for the header. I need a CAD file, preferably in EAGLE *.brd format, or at least the dimensions with the header and the mounting holes. Can you help me?
Message 1 of 1
(1,238 Views)
