Memory Allocation with DAQPAD 6070e
Hi ,
I want to allocate a specified amount of memory in either my DAQPAD 6070e or on my computer which i can then refer later on.I tried using the VISA MEMORY \ALLOCATION function but unfortunately it cannot see my firewire connected DAQPAD(this I beleive is because DAQPAD runs on traditional DAQ drivers). Unfortunately I have not been able to find any other way of doing it.
Can anyone please tell me how i should approach this problem ?
Regards
Manuj
(3,039 Views)
Hi Manuj,
Thanks for your post.
In order to allocate memory for a DAQPad 6070e aquisition/generation you must use the 'AI Config.vi' or the 'AO Config.vi'. These VIs have an input that allows you to specify the size of your buffer (allocated memory for that acquisition/generation) as a number of data points. With this information LabVIEW will handle the memory allocation for you and create the buffer automatically.
Most memory allocation in LabVIEW is handled automatically for you. If the allocation you are referring to does not concern AI/AO buffers, then please let me know. I will be glad to help.
A little more information about what this memory would be used for (data type), and the context in which it will be used would be very helpful indeed.
National Instruments | Northern California
(3,021 Views)
Hi i am attaching a part of the vi here.
in this vi i am having a problem the data gets overwritten before i can read it.....
I am trying to get a data of a daqpad 6070e
I hope this helps else let me know and i will try to elaborate
manuj
(3,018 Views)
