Memory not allocated during DAQmxCreateTask
I am reading 25 analog input channels through code adapted from sample code I found here and developed in MS Visual Studio 2005 in C++.  The created code worked fine but when we integrated it into a larger coding structure, where the program is supposed to begin when a button is pressed, the task creation fails.  DAQmxCreateTask does not initialize the task when the program is run and taskHandle comes up as 0x0000000 instead of 0xsome memory location.  Can anyone please let me know reasons for why this would happen?  The code works on the same computer with the same basic structure (everything after the variable declaration) when it is a stand alone project.  Thanks for any help!  The code that doesn't work is below (sorry about all the smiley faces, I don't know how to not have them automatically show up).
// C_TangibleSensorPage.cpp : implementation file
#include "stdafx.h"
#include "BFMAViewer.h"
#include "C_TangibleSensorPage.h"
TANGIBLESENSOR g_tangiblesensor;
// C_TangibleSensorPage dialog
IMPLEMENT_DYNAMIC(C_TangibleSensorPage, CPropertyPage)
C_TangibleSensorPage::C_TangibleSensorPage()
    : CPropertyPage(C_TangibleSensorPage::IDD)
C_TangibleSensorPage::~C_TangibleSensorPage()
void C_TangibleSensorPage::DoDataExchange(CDataExchange* pDX)
    CPropertyPage::DoDataExchange(pDX);
BEGIN_MESSAGE_MAP(C_TangibleSensorPage, CPropertyPage)
    ON_BN_CLICKED(IDC_IMU_CONNECT_BUTTON, &C_TangibleSensorPage::OnBnClickedConeConnectButton)
END_MESSAGE_MAP()
// C_TangibleSensorPage message handlers
void C_TangibleSensorPage::OnBnClickedConeConnectButton()
    int32       error=0;
    int32       s=5000;
    TaskHandle  taskHandle=0;
    int32       read;
    float64     data[50];
    float64     fulldata[25][5000];
    char        errBuff[2048]={'\0'};
    // DAQmx analog voltage channel and timing parameters
(DAQmxCreateTask("",&taskHandle));
(DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai49","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai50","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
(DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai51","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai52","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai53","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai54","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai55","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai64","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai65","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai66","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai67","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai68","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai69","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai70","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai71","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai57","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai58","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai59","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai60","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai61","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai62","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai63","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai72","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai73","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai74","",DAQmx_Val_RSE,0,5.0,DAQmx_Val_Volts,NULL));
    (DAQmxCfgSampClkTiming(taskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,10000));
    // DAQmx Start Code
       (DAQmxStartTask(taskHandle));
    // DAQmx Read Code
    FILE *OutFile = fopen("aidata.txt","w");
    // Stop and clear task
    for (int i = 0; i<s; i++)
        (DAQmxReadAnalogF64(taskHandle,2,10.0,DAQmx_Val_GroupByChannel,data,50,&read,NULL));
        for (int j=0; j<25; j++)
            fulldata[j][i]=data[2*j];
            fprintf(OutFile, "%f\t", fulldata[j][i]);
        fprintf(OutFile,"\n");
    fclose(OutFile);
    DAQmxClearTask(taskHandle);
(3,991 Views)
mduff,
I can't say off the top of my head why this call would fail.  However, all of these DAQmx function calls should return an interger error code.  If task handle is NULL, I assume that there is probably an error code being returned which may help you determine your issue.
Dan
(3,978 Views)
I forgot I had taken out my error checks during debugging.  I went back and put them in and when I try to break at the line "(DAQmxCreateTask("",&taskHandle));" to see what error I am getting out, the error is still just 0.  And if I try to break after that line, it never exits running so it looks like the DAQmxCreateTask is running indefinitely now.  Is there any reason the CreateTask function would be unable to complete creating the task and would just hang?  Thanks!
(3,961 Views)
Hi mduff,
Hmm... That seems a bit strange.  The one thing that I could think of is that maybe your MAX Database has become corrupt.  I've managed to do this myself a couple of times by killing processes with my debugger or doing other "unfriendly" things to my system.  Take a look at the following link, "How Do I Recover From MAX Database Corruption."
Please note the steps about backing up your current data.  If you create tasks and/or channels in MAX, you will lose these configurations when you perform the steps outlined by the knowledge base I liked to above.
Hope this helps,
Dan
(3,953 Views)
I will certainly look into that.  Would a corrupted MAX database mean that any commands won't run?  Because this particular piece of code does run and collect data when it is stand alone and not integrated into the larger piece of software.  Thanks for all your help.
(3,943 Views)
If it were a MAX database issue, I would expect that it would not work regardless of whether that code was integrated into the larger piece of software or not.  I got the impression from your post that the failure to complete the execution of DAQmx Create Task was a new behavior you were observing.  That may have been a bad assumption on my part.  If the stand-alone code is still working, I would tend to think something else is going on.
Dan
(3,940 Views)
