Module Model Numbers
Hello Everybody,
I am trying to control and monitor
1. temperature (25C to 1400C),
2. measure vacuum pressure,
3. measure and control DC voltage (300V max),
4. DC current (11 amps max)
5. thermal and optical camera to capture pictures.
So I need to know the individual models for these modules that will be compatible for these purposes and with the NI 9172 DAQ.
(3,248 Views)
 it would be compatible Smiley Wink
(3,216 Views)
Thank you for the reply. I need to know the Module numbers for measuring those parameters? If you can help me with that, I shall really appreciate it.
Thanks!
(3,210 Views)
Hey Spat,
You can check out National Instrument's system adviser page.
Here is the link for cDAQ systems.
http://ohm.ni.com/advisors/compactdaq/pages/common/classic/modules.xhtml?conversationContext=1
Sal
(3,198 Views)
