Mouse movement adds noise to acquisition with count edges
I am doing a program that consist on count the pulses of a TTL signal. The problem is that when i move the mouse over the elements of the Front Panel some undiserable and significant counts appear.  I have no ideia why this happens. Do you have any sugestion?
Thanks in advance.
(4,355 Views)
How are you counting the pulses?  Can you show your code?
GCentral
(4,352 Views)
Hows your hardware setup? Where is your signal source coming from, and are you using shielded cables?
(4,323 Views)
Shure i can show you the code, but it´s a bit confusing.
I start the task outside the loop with "DAQmx Create Channel  (CI Count Edges).vi"
And start/stop de task with "DAQmx Start Task.vi"/"DAQmx Stop Task.vi"
Read the values with "DAQmx Read (Counter U32 1Chan 1 Samp).vi" on a case structure with a feedback node. The DAQ count the number of edges during a certain amount of time, like 10 ms, and then print the value.
(4,303 Views)
Chantastic!,
What do you mean by hardware setup? It´s how i  create the channel on NIMAX?
The signal comes from a Function Generator on TTL mode. And yes, the cables are shielded, they are normal coaxial cables.
(4,299 Views)
Your code is really difficult to debug. Would it be possible for you to run a test using only example code for a counter? At the very least, can you save a new test copy of your code, and start removing functionality until you can narrow it down to a smaller portion of your code where you can recreate this issue?
(4,275 Views)
