Multiple Analogue Outputs
I am trying to generate two sine waves, both with different phase shifts and amplitudes on two different analogue outputs simultaneously. I like using DAQmx and succesfully used it for data aquisition, I have been fooling aroung with the examples but could not generate two simultaneous waveforms that have different phase shifts and amplitude. Attached is the example I am trying to modify. I first tried to modufly the DAQmx write.vi to sample multiple channels, but it did not work. I also tried to splitting the task out into two channels and changing it to a dynamic data type but still no result. I am kind of stuck, and will appreciate some direction,
Cheers
Alloush
p.s if there a difference between using this VI instead of onboard regeneration or non variable internal clock
(3,800 Views)
Figured it out!!!
Thank you
Alloush
(3,792 Views)
Can you tell me how please?
Rob
(3,717 Views)
Look at this example program
Dev
(3,691 Views)
