Multiple Cards, Single Trigger
Hello
I am currently using a PXI System with a 6210 (S-Series) and a 6150 (M Series) card. I want to start a measurement immediately (no trigger required).
BUT: Both cards should start at exactely the same time. DAQmx drivers for both cards are available.
Is this somehow possible? What are the keywords I can look for?
Thank you for your help.
(3,057 Views)
You have to synchronize both devices, and configure a digital trigger for one device, that the other device creates. Here you can find an example:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=08877DDDE87408F2E0440003BA7CCD71&p_node=201207&p_source=External
(3,046 Views)
Thank you - That one looks good. I'll try it out tomorrow 🙂
(3,036 Views)
