Multiple Color Pattern Matching
  Good day to you...
  I am studying on the Vision System and try to embed with my DAQ to control some outputs.
http://zone.ni.com/devzone/cda/epd/p/id/5548
  Referring to the link above, this vi has 1 learning template. Do you have any suggestion to learn more than 1 template?
  Pls advise... Thanks
Regards
william
(3,212 Views)
Hi w2k,
Just add more sequence after the first template learning, to learn another template, but please make sure that you use different image to keep each template.
Then, when do color pattern matching, you need to do one by one on different template image.
Regards, Kate
(3,194 Views)
