Multiple Custom Scales within same DAQ
Format into string.
Message 11 of 25
(2,238 Views)
Thanks!
Message 12 of 25
(2,225 Views)
Having trouble making the VI, it keeps throwing me an error of
Error -200088 occurred at Property Node DAQmx Timing (arg 1) in DAQmx Timing (Sample Clock).vi:1-
>DoubleScales.vi
Possible reason(s):
Task specified is invalid or does not exist.
I am using two simdaq channels. Any help would be greatly appreciated. The actual .vi was Number to Decimal String.
Message 13 of 25
(2,221 Views)
It appears that you haven't selected a task to create, so when the property node tries to access this task, there is no task to access.
Applications Engineering Specialist - Semiconductor Test
Message 14 of 25
(2,210 Views)
How do I create a "task" in previous .vi s for data acquisition I always just start with the Create Virtual Channel Vi.
Message 15 of 25
(2,200 Views)
What is the purpose of your 'For Loop'? Just to create an array of channels?
Message 16 of 25
(2,194 Views)
The first for loop is to apply limits to each channel and the second to apply scales to each channel. The for loops are so that you can apply different limits and scales to each channel.
Message 17 of 25
(2,190 Views)
How are you trying to use the property node?
Sean
Message 18 of 25
(2,164 Views)
Which one?
Message 19 of 25
(2,160 Views)
The DAQmx Task property node.
Message 20 of 25
(2,152 Views)
