Multiple Loops of Analog Output without dropping voltage inbetween loops
I have a program for a test rig where I need to output an array of data as analogue voltages, and I want to be able to do this multiple times without dropping the voltage momentarily between loops.
I am currently using a while' loop within a for loop, and using the 'Is task done' node to stop the while loop at the end of my array, so I can set how many times the for loop runs to output the array multiple times. Simplified example of my code attached.
However the way it is set up means I get a momentary loss of voltage output as it stops the write task and starts it in the next iteration of the for loop.
I have tried using continuous samples and outputting one longer array instead of multiple loops of a smaller array, however as the arrays I need to input can be very long, I have run into buffer size limitations. I also require the user to have some feedback about how far into a test they are, so at least with multiple loops of shorter arrays there is visibility of how many times the for loop has run.
Does anyone know of a way to output multiple loops of an analogue output while maintaining the last samples' voltage between the loops?
Thanks in advance,
(3,054 Views)
I added the code here
(3,020 Views)
I will have a look and let you know
(3,019 Views)
Hi Raz21,
It's not FGPA, I'm just using a cDAQ9184 chassis (ethernet connection) with a c-series (NI-9264) output module
(3,009 Views)
Hey,
Yeah, I realized that afterward. I had a different project opened and LabVIEW got confused saying that your code is in FPGA.
Ignore the FPGA part.
Let me know if the above solved the issue.
(3,005 Views)
That didn't seem to solve the issue as I got the following error 'generation cannot be started because the output buffer is empty' (screenshot of error attached). Presumably I cannot have the start  before the write if I am buffering an array of data to output ?
(2,981 Views)
Yes, I realized that just after I sent you the code. I have reorganized the code and tested it. This should be fine.  Capture.JPG
(2,973 Views)
