Hello;
To output different waveforms on the Analog output channels, you just need to change the buffer array of data points that will be output.
The array will be output in a way that its first data point goes to channel 0, second data point to channel 1, third to channel 0 again, fourth to channel 1, and so on.
Therefore, in case you want to modify the waveform that goes to channel 1, you just need to change the data points of odd indexes of your array.
Regarding your second question, the upper and lower limit are the input range expected for your signal. That will automatically set the best gain to fit your signal to the full range of the ADC.
You can get more information about a specific component in the ComponentWorks on line help installed on yo
ur machine.
Regards
Filipe A.
