My NI cDAQ-9191 is no longer displaying the installed module in MAX.
I just purchased a cDAQ-9191 chassis with NI 9219 AI module.  Initially MAX showed both the 9191 and 9219 under network devices.  However, after several hours of messing around with the wireless settings and pressing the reset button several times, MAX no longer shows the 9219.  Nothing dramatic happened to the hardware (i.e. it wasn't dropped or mishandled) so I suspect a self inflicted software problem.  The NI technician recommended I "Reset Configuration Data" in MAX, which I did, but that didn't fix it.  Has anyone else had this sort of problem?  Any suggestions?
(2,958 Views)
Accepted by topic author cmcnabb
problem solved... several of the NI network services had stopped.  The module appear after I restarted the services.
(2,955 Views)
