My PID controler seems not work properly.Can this be caused by the 1s period of the timed loop?
Hello guys. I am building one labview (8.5) aplication to control 2 ovens temperature. I am using two PID controlers to control each oven separately.But what hapens is that after i establish one value for the Kp parameter (apliyng the Ziegler-Nichols rule), i made one temperature test with Ti=200s and with Ti=0.1s and i was expecting that the final error(steady state error) of the temperature should fall(thats one control rull , when you decrease the Ti value the steady state error decreases).
So my question is , can this beying appening because the PID's (for both ovens) are in one timed loop of 1 second ,and this can cause the integration to be restarted (or so) at eatch second?
Many thanks
JOSE
(2,947 Views)
could you please give me more detailed info about your temperature control loop?
(2,913 Views)
