MyDAQ is not recognized on Variable Power Supplies
Hello everyone!
I want to connect myDAQ made by National Instruments to my PC and output the specified voltage using Variable Power Supplies of the ELVISmx Instrument Launcher application, but Variable Power Supplies does not recognize myDAQ. However, as you can see in the picture attached on Variable Power Supplies, the connected myDAQ is not recognized. However, as shown in the second attached photo, another device such as Digital Writer is recognized.
How can I solve this problem? I need your help. Thank you in advance.
(729 Views)
NI myDAQ hardware requires NI-ELVISmx and NI-DAQmx drivers to be installed.
NI myDAQ Driver and Software Requirements
Getting Started with NI myDAQ
https://tmesystems.net/
(722 Views)
