NEED DAQ SUGGEST!
Hello! I need a suggest about DAQs. For a project we need minimum 8 channels data acquisiton board. These channels may be used for generating analog signals. We have SCB-68E and 6221 DAQ. But when we acquire two different signal, we can not arrange two different sampling frequency. So we need a DAQ and usb i/o board to acquire signals different sampling frequency. For example, i may generate 1KHz sinus signal, record temperature sensor data with 1 Hz and record accelerometer sensor data with 200 Hz in the same time. Can you suggest me a  National instruments product for this purpose?
(2,590 Views)
Anybody wants to help?
(2,443 Views)
You might want to look at using cDAQ.  A single chassis can have multiple acquisition clocks, so read the specifications carefully to find one that will work for you.  But first, look at the modules to determine what modules and how many you will need.
(2,441 Views)
What is the generation part??
However.. Just configure the input ranges  and output ranges .. use the max sample rate you need for one task.
For reading :Use a producer-consumer scheme and decimate the channel data that 'need' lower sample rate....
Greetings from Germany
Henrik
LV since v3.1
(2,437 Views)
