NI 6002 Data Acquisition with two channels at the same time
Hello Everyone,
I have a question is it possible to read analog and counter channel at the same time with two different time loops in NI USB 6002. I am having problem that when analog signal is reading I am not able to read the counter values and when reading of analog channel is finished it starts reading counter values but then i loose some counter values.
Please help me in this
(3,234 Views)
I believe you should be able to do what you describe, you just need to have separate tasks for each. Maybe you should post your code so we can see what exactly you're doing.
(3,199 Views)
 Yes,I am initializing two seperate tasks for counter and Analog channel. Below is my code logic
// Call Initialize channel functions
void manualMode::initializeChannels()
const char* waterCounter= "Dev1/ctr0";
const char* linecounter= "/Dev1/PFI0";
ni6002.intinalizeCounter(waterCounter, linecounter, samplesPerSecond);
const char* pressurechan="Dev1/ai0:2";
ni6002.intitializeReadAnalogPressure(const char* chan);
// Start Time Loop
void manualMode:: startTimeloop()
startCounterDataAcquisition =new QTimer();
connect(startCounterDataAcquisition, SIGNAL(timeout()), this, SLOT(getCounterData()));
startCounterDataAcquisition->start(100);
startAnalogDataAcquisition =new QTimer();
connect(startAnalogDataAcquisition, SIGNAL(timeout()), this, SLOT(getAnalogData()));
startAnalogDataAcquisition->start(100);
//"getCounterData" and "getAnalogData" function(Time Loop Functions) will be called every 100ms in a time loop
void manualMode::getCounterData()
readCounterData=ni6002.readCounter();
memmove(counterBuffer, readCounterData, sizeof(double)*(samplesPerSecond/10));
counterBuffer+=(samplesPerSecond/10);
readAnalogData=ni6002.readAnalogPressure();
memmove(dataBuffer, readAnalogData, sizeof(double)*3*(samplesPerSecond/10));
dataBuffer+=3*(samplesPerSecond/10);
void manualMode::getAnalogData()
TaskHandle taskHandlePressure = 0;
TaskHandle taskHandle1 = 0;
// Initialize Counter
void NI6002Communication::intinalizeCounter(const char* counter, const char* linecounter,
int samplesPerSecond)
DAQmxCreateTask("counter", &taskHandle1);
DAQmxCreateCICountEdgesChan(taskHandle1,counter,"",DAQmx_Val_Rising,0,DAQmx_Val_CountUp);
DAQmxCfgSampClkTiming(taskHandle1,"",0.1*samplesPerSecond,DAQmx_Val_Rising,DAQmx_Val_ContSamps,
0.1*samplesPerSecond);//sampTerm
DAQmxStartTask(taskHandle1);
// Initialize Analog
void NI6002Communication::intitializeReadAnalogPressure(const char* chan)
int samplesPerSecond= directoryTab.settings->value("Prefill_Sample_Rate_Hz").toInt();
DAQmxCreateTask("pressure", &taskHandlePressure);
DAQmxCreateAIVoltageChan(taskHandlePressure,chan,"",DAQmx_Val_RSE,-10.0,10.0,DAQmx_Val_Volts,NULL);
DAQmxCfgSampClkTiming(taskHandlePressure,"",0.1*samplesPerSecond,DAQmx_Val_Rising,DAQmx_Val_ContSamps,0.1*samplesPerSecond);
DAQmxStartTask(taskHandlePressure);
// Read Analog
double* NI6002Communication::readAnalogPressure()
int samplePerSecond= directoryTab.settings->value("Prefill_Sample_Rate_Hz").toInt();
int32 samplesReceivedPressure = 0;
DAQmxReadAnalogF64(taskHandlePressure, 0.1*samplePerSecond, 10.0, DAQmx_Val_GroupByChannel,
dataPressure, 3*0.1*samplePerSecond, &samplesReceivedPressure, NULL);
return dataPressure;
// Read Counter
double *NI6002Communication::readCounter()
int32 samplesReceivedcounterdata = 0;
DAQmxReadCounterF64(taskHandle1, 0.1*samplePerSecond,10.0, counterdata,0.1*samplePerSecond,
&samplesReceivedcounterdata,NULL);
return counterdata;
(3,187 Views)
// Start Time Loop
// Read Analog
// Read Counter
return counterdata;
(3,179 Views)
