NI 6009 analogue output
Hi All,
I have a couple of problems with my NI 6009 USB DAQ:
1. In labview connecting the DAQ assistant (configured for analogue output) to a sine generator leads to two problems:
- The actual output when viewed on an oscilloscope is discrete (each wave consists of 8 peaks) rather than a continous spectrum. (Generator set to output 1 point)
- If I set the sine generator to output 1000 data points there is an error generated "the number of items in the data [input to DAQ] is not the same as the task".
Telling the DAQ to output continous data (attempting to match data and task) results in an error - "can only select 'OnDemand'"
2. The noise on the analogue inputs is of the order of 10's of mV, this rather seems to defy the object of having a 14-bit input with accuracy of 3mV. (+/-5V)
LabView is a testing stage before we move to python wrapped C drivers, but we need to prove that the device actual does what it claims to before we can move on.
Please can the knowledgeable readers advise.
Durham_student
(3,508 Views)
I'm not sure what you think the device claims to do but the specs state that the analog output is strictly software timed and can only do a max of about 150 updates/sec. You cannot write more than a single point and you cannot select continuous data. See this kb article.
(3,500 Views)
Thanks for the reply,
~150Hz might do the trick, but I'm getting maybe 1Hz. The DAQ assistant is in a while loop and set to excecute as fast as possible.
I definately need it to hold the output voltage whilst data is taken in.
Thoughts?
Message Edited by durham_student on 11-03-2009 02:24 PM
(3,495 Views)
Have you tried the example that's in the kb I linked? That does not use the DAQ Assistant.
(3,491 Views)
