NI-6023 digital inputs miss line state-changes
I am using the NI-6023 DAQ to monitor digital lines. Occasionally (less than 1% of the time) the 6023 misses a low-to-high line state-change from . LabVIEW 6.1 polls the 6023 every 5 mS. The digital lines are normally low. When they go high, they remain high for only 50 mS.
LabVIEW 6.1
Windows 2000 Professional
(3,153 Views)
Are you sure it really is polling every 5 ms? Have you used the timer functions to verify the timing?
Randall Pursley
(3,146 Views)
Hi Rchrd,
If you're using a loop to poll your digital line, it's possible that you're not actually polling every 5 ms, since this is software timed. The speed is software/computer dependent, hence can depend on factors such as processor activity. Software timed I/O is normally used for low-speed applicatiosn that do not need hardware timed precision. You can do some troubleshooting by checking to see if there's a certain condition under which the state change is missed, and making sure you don't have other applications runing.
Hope this helps.
Lesley Y.
(3,141 Views)
