NI 6030E external reference select
I am attempting to use the external reference input with AO (Analog output channel 0) to scale the output.  Has anyone done this successfully or tried & failed?  I have a PCI-MIO-16XE-10 (6030E equivalent) with a CB-68LPR block (low profile right angle).  The manual indicates that what I want to do is possible.  If I connect +5v to J20 (AO Ext. Reference In) then I would expect the AO-0 (J22) to be either uni-polar 0 to 5 or bi-polar -5 to +5.  I can make the uni/bi selection on MAX Test Panel, but the AO-0 uses the internal 10v reference.  I do not find a selector for int/ext reference.  Is there an external reference selector? Have I missed something?
Thanks in advance for suggestion & comments.
RunningDog
(3,084 Views)
Never mind.  Problem solved.  I found an example that used an external reference.
RunningDog
(3,065 Views)
