NI 6124 AI GND
Hi
I have a question about the AI GND signals on the NI 6124,
is the pins AI 1 GND, AI 2 GND, AI 3 GND and AI 4 GND connect to the same ground?
Or is the AI GND pins isolated from each other?
//Peter
(3,124 Views)
Yes, the AIGND are internally connected
Greetings from Germany
Henrik
LV since v3.1
(3,102 Views)
Ok, thanks, do you also know if AI GND is connected to AO GND on the NI 6124?
//Peter
(3,095 Views)
Again, Yes, they are connected. However since every current (incl. ground loops) in a PCB trace create a small voltage drop in that trace, it is recommended to use the according GND connector.
Henrik
LV since v3.1
(3,073 Views)
