NI 6221 37 PIN Analog Input problem
I have a NI 6221 37 PIN card and would like to read analog voltages. I am contacting my signal cables via a D-SUB connector, like one you can see on the pic. It has 37 PIN, mother D-SUB connection on the front and a solderable backside.
http://hu.farnell.com/fci/dc37s064tlf/connector-d-sub-receptacleacle/dp/2293762
My problem is, that I always measure + or - 10,6 V, when the range is set to +/-10 V and I measure +/-5,3 V at the range of +/- 5V. I tried almost all types of connections from page 58 of this manual (ground referred NRSE would be my preferred):
http://www.ni.com/pdf/manuals/371022k.pdf
I ran the NI DAQ Diagnostic Tool 2.1, the self-test of the MAX and none of them reported any failure. What can be the problem?
Thanks!
Message 1 of 9
(4,545 Views)
Sound like open analog inputs that a saturated by bias currents.
If you shortcut the AI0 to AGND, what do you measure?
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 9
(4,519 Views)
I tried it and had the same reading. I also shorted it with the digital GND and got the same...
Message 3 of 9
(4,514 Views)
shure you made the correct connections?
I still vote for open inputs
Henrik
LV since v3.1
Message 4 of 9
(4,512 Views)
I tried it again, and still got the same results. I also got a NI 6008, and with the same connections that one works. But I still want to use this 6221. I do share your opinion about open circuits, it's just that I cannot imagine what I forgot. Is there a PIN maybe that I always have to connect to a supply or something? So far I only connected the signal and the ground wires.
Message 5 of 9
(4,507 Views)
Both cards have different connectors 😉
I have seen (not only once, not only fabricated by me 😉 ) false counted pins on multi pin connectors, broken wires, cold solder connections, ...
Henrik
LV since v3.1
Message 6 of 9
(4,505 Views)
I agree with Henrik at this moment, check out if you have the proper soldering, it seems more of a connection issue than device problem.
I.R.
Message 7 of 9
(4,482 Views)
You were right, it was really the connections. Now it is workig. As a side note: the pinout drawing on the datasheetconfused me a little, as it numbers the pins as you  can see them on the mother connector and not as on the card-connector. But anyway it is OK now. Thanks.
Message 8 of 9
(4,469 Views)
Thanks for comming back 🙂
Henrik
LV since v3.1
Message 9 of 9
(4,459 Views)
